Smart lock issue
sjp
Location
manitoba
Looking for some input on my issue I’ve had since last year. 22 defender xmr get a random “check smart lock” and p3407 code. Problem I find is the front diff is not totally unlocking or releasing from 4x4 Once changed back to 2wd, if I remove the actuator I can hear the spring return in the diff and it opens up like normal and front wheels turn independently of each other.
Replaced diff actuator as I found it had a hole in it, checked fuses, checked wire harness on the diff the best I could (I don’t have a volt meter at home to ohm it out), checked speed sensors and cleaned no luck
Any thoughts on this? Possibly the switch? Hasn’t been back to the dealer in 3 years maybe software update? Did having that hole in the actuator letting water in short something out in that front diff module?
sorry no input here, dont have smartlok on my hd10 xt, have it on my x3 but havent had any issues with it on there.
