Tired Of Manually Adjusting Snowplow
harleyrider121
Location
Wisconsin
Hello - my first post here. I have the Can-Am Pro Mount steel snowplow blade and bracket on my 2018 Defender XT HD10. Thinking of adding some sort of angle control to it. I don't have the ability to make my own brackets or do any welding. Are there any kits out there that you have used?
Thanks
We have this model on our 24 Defender HD10 6x6
works very well worth the $$
Thanks
I have a 2023 can am defender HD10 with the can am plow & actuator. It works great until it doesn’t work at all. While plowing a month or so ago, the actuator just quit & it was stuck in an awkward position. I think the actuator die as a result of low voltage which is another story. So my buggy is in the shop getting a second battery kit installed which I highly recommend if you’re plowing & it’s getting an new actuator installed. Total cost $2k. If you can possibly utilize any after market plow/actuator system other than can am products, I would highly recommend that.
Thanks
I have a 2020 Defender with a KTI Open Trail plow, mounting bracket, and actuator that I have used for 3 years with no problems. I plow a lot of snow in northern North Dakota.
