If you or your dealer can check to see if the charging voltage is 13.6 to 14.4 when the engine is running than your stator is charging as designed.
The problem seems to be that you are drawing more current when plowing than your stator can put out at the RPM you are plowing at. The stator puts out maximum current at 4400 RPM and your dealer can check that on the spec sheet.
If you are concerned about parasitic draw check your battery voltage after you finish plowing with the engine off, it should be at 12.8v +/-. Disconnect one of the leads at the battery and recheck the voltage, it should be the same as before. If the battery voltage is lower than you have found the answer is not enough charge to replace the amps used for plowing. If your battery drops below 12.2 volts at any time you are below 50% discharge and start to damage the battery to the point of being unable to fully recover. A 32 amp/hr battery is at 50% when it produces 16 amps.
Leave the battery disconnected for several days no battery tender hooked up and check the voltage, it should be the same as the last time you checked.
You can check parasitic draw by placing an amp meter around one of the battery cables, if you don't have one start pulling fuses until you determine which circuit has the problem. You can also check current flow across the fuses with a good multimeter.
Charge the new battey with a battery charger not a battery tender to be sure you are giving the new battery a full charge.
Placing a second battery or a larger battery in the system will give you more time before you discharge both batteries when plowing. You will have to charge both batteries with a battery charger so they are full for your next job after each job.
850 watts/volts=amps, so if you want to have a fully charged battery at 12.8 volts you can only get 66 amps at 4400 RPM or above. This has to supply amps to the fuel pump, injectors, ignition, dash display, headlights etc. before you have any amps to recharge the battery and supply current to your other accessories while plowing. If you have heated seats, heater, etc. write down what each of those draw and I think you will see where your charge current is going. As an after thought check your voltage at the battery with the engine running at idle and all the accessories that you are using turned on. Now push your winch button and turn your power steering both use alot of current. Rev the engine up to 4400 RPM and repeat and see what the max voltage gets to. I think you already knew most of the above info but breaking it down may help manage the problem.
I have a 19 Defender Cab XT, HD10 with heater and I added an LED bar light for the front and a small one for the back, with a winch in front and a winch at the back, both 4500 and I am still on my original battery but the first thing I checked was the size of the stator but I don't plow with it. I charge the battery in the spring before use and fall before I park it. No battery tender on any of my toys or vehicles and very good battery life.
Good luck with finding a solution to your problem.
